DVDV/DVBSRV 4 streaming bug
niknas
using latest release of DVDBViewer and DVBServer in combination there is a problem.
This is a previously working configuration using DVBViewer 3.9.4. I have now upgraded to v4.
After a few windows updates there was a problem using DVBServer. Using the locally installed tuners directly with DVBViewer works OK, but whenever I try to set DVBV to use Unicast adapter and DVBServer, I can see in DVBServer that both the control and streaming client connects, but there is no data coming.
Data rate is 0 in DVBServer and looking in DVBV in DVBSource I get "Not connected" under Video/Audio state.
I have tried this using DVBV and DVBSrv on the same machine and with a remote DVBV, still the same results. Firewall turned off, using FireDTV BDA drivers 4.5N and 5.3N yields the same results. Latest firmware upgrade for the FireDTV cards.
Any ideas?
Thanks,
Niklas//
<entry name="DetectVideo">1</entry>
<entry name="DetectAudio">1</entry>
Disable it in the directx options of the DVBViewer. Does cause problems with network devices.
