web server ext?
Dython
is there a way to change the file type of the server to let say mp4?
Please explain.
Remember: Putting the label "gold" on a piece of steel doesn't make it gold.
the webserver only suports vlc and wmp.
but mobile ( and maby android ) suports mp4and h264. thats way.
Mobile tv is wat i'm aming for.
Please explain.
uum disable emmbedded and you wil see only vlc and wmp
and i do mean file type , mp4 or 3gp
android woont even play its becouse it isnt a mp4 or 3gp.
Edited by Dython
i thing the payer is the file type but only wmp or vlcis there ,is there a way to add one?
Edited by Dython
you can transcode the stream on-the-fly if that's what you want.
you dont get it .
oke for me to be able to play a vid , a file extension must have mp4
so if i stream , the file must be ######.mp4
but with the server its only a vlc or wmp file.
thas wat i want to change file extension
and not the kind of muxer or codec
..renaming won't do the job. You have to transcode the content.
  • 3 months later...
I am new to the DVBViewer. I try to do the transcoding/streaming with the DVBViewer with VLC. I use a VLC client to receive the video streaming over the LAN. However it seems that the network traffic will not reduce with a lower bitrate and size that is shown on the stream set up screen menu. I use the task manager to monitor the network traffic and the traffic is the same no matter how I change the options on the stream menu. Can you give a hand on this ? Thanks.
