mborkP Posted March 14, 2009 Posted March 14, 2009 Hi, I bought and setup DVBV on Vista Home 32bit system. The software works lovely with 1 card. When I put second card it is detected by the system all seems be ok. I start DVBV and it runs ok. When I scan for devices in hardware section the second card is detected and cards are numbered as 1 and 2, great. When I save and try to watch the tv, there is no pics or audio. I can't do scanning as well, no transponders detected. If I remove one of the two devices in DVBV hardware section, nothing changes, still no picture. But when I paste hardware.xml created with 1 card over newer created with 2 cards all works ok again. Can someone please help me with this issue? Thanks, Mick Quote
Lars_MQ Posted March 14, 2009 Posted March 14, 2009 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
mborkP Posted March 14, 2009 Author Posted March 14, 2009 Sorry, I'm at work now so I will prepare required info when I get home. Thanks, Mick Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
mborkP Posted March 15, 2009 Author Posted March 15, 2009 (edited) Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Hi, I've been playing with my PC and I got some progress.Now the program is tunning while 2 devices are recognised But I can't get any programs to play. I got DigitalTV (program which came with the card) working ok. Two TV cards: AzureWave AD-SP400 (Mantis 1041A) driver 1.0.4.0 Main Board: Asus P5K (Intel775) Video: Nvidia 8600 driver 181.22 No CI, FTA only Thanks, Mick support1card.zip support.zip Edited March 15, 2009 by mborkP Quote
mborkP Posted March 16, 2009 Author Posted March 16, 2009 (edited) Hi, i again, some more testing done. The program works ok with each card bat not both at the same time. 2 cards installed, seen by DVBV. card 1 normal, card 2 not in use: scanning the card gives me signal (green bar at about 3/4 lenght) but PAT yellow, PMT and SDTshow nothing. card 2 normal, card 1 not in use: scan ok, PAT,PMT and SDT ok. While watching TV it shows channel (call it A) When switching to B no picture. Rebuilding Graph brings picture on B. Switching back to A does not show picture but rebuilding Graph again show the pict on A. And so on. On shutting down windowsit take time and I got BSOD. Computer restart on its own. Could be a Vista or driver or hardware problem (does not happen with one card inserted) Next I put SkyStar2 as secondary card and install v.4.5 driver for it. Both cards scanning ok. I can get picture when using SP-400. When using SS2 I get all the data and stream info but no picture/sound. Well on occasions I get half frame and some very choppy audio. Does SS2 cards work ok with DVBV at all ? Thanks, Mick support.zip Edited March 16, 2009 by mborkP Quote
mborkP Posted March 17, 2009 Author Posted March 17, 2009 (edited) Hi, time to finish this monologue....anyway couldn't get sp-400 and ss2 to run together. Two ss2 paired works ok thou . Cheers Edited March 17, 2009 by mborkP Quote
