Dinex Posted March 17, 2009 Posted March 17, 2009 I can't tune the DVBViewer on the recession channels Platforma HD on the Satellite Eurobit 9A. My card DVB-S2 TeVii S460. Vista 86x. The other channels are good work. Can you say what the problem? Quote
Derrick Posted March 17, 2009 Posted March 17, 2009 Maybe the transponder parameters are not correct. When performing a NIT search a wrong satellite descriptor is put in the transponder.ini. http://www.DVBViewer.info/forum/index.php?...st&p=237319 Try this ini with transedit Quote
Dinex Posted March 18, 2009 Author Posted March 18, 2009 Maybe the transponder parameters are not correct. When performing a NIT search a wrong satellite descriptor is put in the transponder.ini. http://www.DVBViewer.info/forum/index.php?...st&p=237319 Try this ini with transedit Ty! Best regards! Quote
