B2C2 Card - Which drivers ?
Sooty
I have a B2C2 DVB Card installed and was hoping to us DVBViewer for my Sat channels. I am however unable to see any video signals on the DVBViewer window.
I am wondering whether I have the latest and most up-to-date drivers for my B2C2 card ???. The one I have is dated 05/02/2002 !!!
Which is the best version to use and why. I have been able to open MPEG files and play them all ok so there is no problem with my graphics card !!!!.
Any help would be appreciated as DVBViewer loooks great.
Thanks.
Are You Eol, Netsystem, or T-dsl client?
If you are Eol Client remove drivers and install this one:
The current drivers from technisat are version 4.22 Last Update: 21.06.2002
url -> '' ftp://download.technisat.com/en/soft/448.zip ''
dont forget to reg card at Eol
please read my previous post! will help you reg your broadband card
if not!
Please post your system info example : motherboard chip set, bios revision, Cpu, Graphics card ...
Netsystem user.
Should I use the technisat drivers of not ????.
Cheers,
Sooty.
AMD Athlon Xp1700+
512mb RAM
Inno 3d Tornado GeForce 4 Ti 128mb graphics/ tv-out card.
Guest hackbart
take a look in your hardware manager. There should be an entry (under Network Devices) called B2C2 Broadband receiver PCI Adapter. Double click on it and the driverversion will be displayed under the Tabsheet Driver.
If the version is >= 4.0.1.0000 then the next release of the DVBViewer should work fine (incl. EPG and Teletext).
Christian
