Crashing on start-up.
Kevin Steggles
Hello,
I've recently downloaded v4.0, and ever since, when I run DVBViewer, it opens up ok and goes to the main screen, but then locks up and I have to ctrl-alt-delete to get rid of it.
Strangely, when I tried it out over remote desktop from home last night, it appeared to work fine!
I'm using a Freecom DVB-T USB stick using driver version 2.0.1.8
ConroeXFire-eSATA2 Motherbard with Intel i945G/GZ chipset Rev A2
Radeon X1950 Pro graphics card using driver version 8.591.0.0
Update - I now get sound, but no picture on starting up. I can't access any menu items, and after about 30 seconds, it completely crashes.
try start -> programs -> DVBViewer program group -> support -> DVBViewer (Safemode)
This starts the Viewer without tuning a channel.
Now go to options -> directx and try another video decoder and/or renderer.
That seems to have worked - a useful tip there, thank you.
I've switched the MPEG2 video decoder to Arcsoft MPEG and the renderer to VMR7.
It now works from normal start-up.
Thanks!
