How to "receive" stream with DVBviewer?
MomoBrut
I use VLC to show streamed programs from DVB-T multiplex. I have got server with getsream-poempel, which can send programs from multiplex to different ports and uses TCP or UDP. In VLC is necessary to specify the IP and port and stream is showed ...
Is there any possibility, to show this streams with DVBViewer?
Thank you. MB.
Not really. If you have luck it will work. But it will not be comfortable.
If you change for streaming from getsream-poempel to DVB Server or the Recordingservice it will work without problems but thy did not work on Linux.
I tried open url of course, but it did not work.
The problem is - I am not the one who should receive the stream ... vlc is free, DVBViewer is not ... anyway, can anyone help with directshow filter chain that will be able to work ...
Thank you.
