Judder in full screen and using menus...
Irrotational
Apologies that my first post is a problem!
Installed DVBViewer and everything was fine...however the video judders a lot when in full screen mode or using the DVBViewer menus.
I have tried switching from vmr7 to vmr9 and EVR - all have some problems, with EVR worst, vmr9 second and vmr7 is best.
CPU usage is 40%-60% in all modes - not noticeably higher in any of them.
Using options->view->filters I can see I am getting lots of dropped frames in full screen mode
My computer is old so I am wondering if the gfx card is too slow?
Support file is attached
bugger - sorry! i meant to post this in Newbies forum - I am not claiming it is an official "bug" - sorry!!
Did you try the "overlay" mode? It is by far the one that requires the less resources, so it may be a good option for you. I consistently have CPU usage of 1-2 % in overlay mode with DVBViewer.
Also you may want to try another MPEG2 decoder.
Thankyou for your prompt response...
I should have said I tried overlay as well, plus the standard mpeg2 decoder and an arcsoft one...neither made any difference.
All options resulted in the same 40%-50% cpu utilisation.
I wasnt sure if it was resource related as MCE can play TV fine in full screen...
I should also say these are standard def channels so nothing to do with HD.
