calande Posted March 21, 2009 Posted March 21, 2009 Hello, It's rather an annoyance than a bug, but it should be addressed. In my Favorites list, I have all my TV channels sorted properly, starting from channel #1, channel #2, etc...The problem is that the counting starts at 0 instead of 1. So to watch channel #1, I have to press key 0. If I press key 1, I see channel #2. It's rather misleading. I found a temporary solution until it's fixed: I assigned channel #1 to both key 0 and key 1. So, if I press key 1, now I see channel #1, if I press key 2, I see channel #2, and so on... But if I switch from channel to channel, from channel #1 to channel #2, to the last channel, at one point, I go back to channel #0, and then to channel #1 (at this point, I see the same channel twice). So it's still awkward. I would remove the #0 entry and start from #1. Thanks for your comprehension, Quote
Tjod Posted March 21, 2009 Posted March 21, 2009 This is no bug. The channel Numbers start with 0. Quote
Gioxy Posted May 22, 2009 Posted May 22, 2009 I'd like them to start from 1 as well. No way. It's a long and very old story, just check the forum... Anyway there is another simply and, all in all, comfortable workaround: use the "0" channel for some other useful channel... Quote
calande Posted May 22, 2009 Author Posted May 22, 2009 I yet have to see a television that starts with #0 A DVB player is no different. Quote
