Cinergy 1200 BDA Initializing
dyter
I have a PCI Cinergy 1200 DVB-C and PCI-E Pinnacle 3010iX DVB-T cards
On the firt windows start, when I switch on Cinergy, the video don't appear, I need to restart DVBViewer, reset the BDA in proprety, or switch on other channel between my second BDA card for show my DVB-C Channel.
The problem is same without Pinnacle card installed (installed later).
Is there a tweak program for reset a BDA driver ?
Thanks
  • 1 month later...
I found: It's a bug on all PCI Cinergy 1200 DVB Device
Any solutions for auto restart BDA Drivers of PCI Cinergy 1200 DVB cards ?
Edited by dyter
  • 9 months later...
Hello,
I have Cinergy 1200 DVB-C which work fine with following Hardware settings:
Following settings are enabled:
-Stop stream while tuning
-Direct tuning
Other settings are disabled.
Retune on missing stream after (sec.): 2.
Using latest driver 4.8.3.18 from http://ftp.terratec.de/Receiver/Cinergy1200DVB-C/Update/.
Hopefully these are useful.
Edited by jakeh
