bormoley Posted March 25, 2009 Posted March 25, 2009 Hello I'm not sure if it is a bug, but I'd like to ask you to increase timeout before switching chanels by pressing +/- keys (actual max is 2000ms) You may ask: what is this for? the answer is - to see next channel info and EPG before channel switch procedure(takes some tine and OSD disappears while repainting). I'm using DVBViewer on HTPC with remote and, as for me, it should be useful. As a Wish to this post it would be nice to have some kind of osd channel list for HTPC users for easier using of remote control (today it is too difficult to control viewing process/ not like on regular receivers) Thank You. Quote
Tüftler Posted March 25, 2009 Posted March 25, 2009 You can use "OSD-Senderliste"(OSD-Chanellist) or "OSD-Favoritenliste"(OSD-Favouritelist) for EPG-Info. Set a individual keyboardshortcut for this options: Right mouse -> Options -> Input hopefully this is what you mean Quote
