hill79 Posted March 25, 2009 Posted March 25, 2009 Hi I have MCE remote PHILIPS under VISTA 64. In MCE is full functional but it DVB Viever with myMCE2005 not. Thanks for any help. Hill Quote
SnoopyDog Posted March 30, 2009 Posted March 30, 2009 (edited) More details please Does none of the keys work or only some keys don't work? The "original" MCE remote control is also manufactured by Philips: http://www.remotecontrol.philips.com/libra...ments/RC153.pdf Did you try my MCE plugin? Look here: http://www.DVBViewer.info/forum/index.php?showtopic=28849 It's in german, but if you need support in english, just ask... Edit: Which specific remote do you use? Edited March 30, 2009 by SnoopyDog Quote
Topogigi Posted March 30, 2009 Posted March 30, 2009 More details please Does none of the keys work or only some keys don't work? The "original" MCE remote control is also manufactured by Philips: http://www.remotecontrol.philips.com/libra...ments/RC153.pdf Did you try my MCE plugin? Look here: http://www.DVBViewer.info/forum/index.php?showtopic=28849 It's in german, but if you need support in english, just ask... Edit: Which specific remote do you use? Hi, I also tried your plugin with the Asus Nova Lite PX24 remote, but it works only for some keys (excluding the keyboard-mimic numerical keys that are working with or without any plugin). I would be very glad if you are going to support other MCE remotes and the Asus one in particular. I can post here all the non supported codes using your debug plugin, if you need them. BTW, the remote I am talking about is this: http://image.mml.com.tw/attach/mml-567e6f9...994b89ac29.jpeg It's the same that's bundled with the eeebox B206. So if you will support it, you'll make happier EEEBOX users too... Quote
SnoopyDog Posted April 19, 2009 Posted April 19, 2009 Hm, if none of you posts more usefull information i can't help you at all. Quote
Angus Lam Posted July 20, 2009 Posted July 20, 2009 Hm, if none of you posts more usefull information i can't help you at all. Hi, I am using the mce remote of Compro TH350i, I can try to learn some key in DVBViewer and works fine. But when I reboot my PC, all the key reset and I need to set it again. Besides, when I try to set some action to key, it can perform what I want, but it also call up the Media Centre, how can I stop the action to call up MC ? Thanks ! Quote
Angus Lam Posted July 20, 2009 Posted July 20, 2009 More details please Does none of the keys work or only some keys don't work? The "original" MCE remote control is also manufactured by Philips: http://www.remotecontrol.philips.com/libra...ments/RC153.pdf Did you try my MCE plugin? Look here: http://www.DVBViewer.info/forum/index.php?showtopic=28849 It's in german, but if you need support in english, just ask... Edit: Which specific remote do you use? Hi, I am new to the DVBViewer and would like to use my PC as HTPC, so that no more mouse and keyboard needed. I would like to have your plugin "English" version for reference. Besides, I saw some plugin of other people and find that it seems to be written in XML, I am interest on this and want to modify it for myself, but I have some question is how can you guys know the value of those parameters ? For example : <Group Name="Channels" ID="1" System="-1"> <Command Name="Channel Minus" Value="8" ID="8" System="-1"> <Event Source="Keyboard">Add</Event> <Event Source="MCE2005">Channel_Up</Event> </Command> How can u know the command name is "Channel Minus" and its value is "8" ? And how can u know the value should be "Channel_Up" in "MCE2005" plugin ? Thanks ! Quote
SnoopyDog Posted July 20, 2009 Posted July 20, 2009 Hi! This plugin has no language. Only the thread i mentioned is in german... Quote
Angus Lam Posted July 20, 2009 Posted July 20, 2009 Hi! This plugin has no language. Only the thread i mentioned is in german... Can u let me have the English version of the thread ? Thanks ! Quote
