Stutter after exeting osd menus with dxva enabled
Björn Rosberg
If I enable dxva in the mpeg2 decoder I get choppy playback after exeting osd menus/pages like for example teletext pages. When switching channels the stutter will go away. This is only when dxva is enabled.
My graphic card is a geforce 5200 wich I have over clocked slightly. I have also been playing around a bit with different 3d-settings in the nvidia control panel with no success.
I use powerstrip to force 720p 50 Hz since I'm not allowed to do this in nvidia control panel. In dxdiag I also force 50 Hz.
I would like to be able to use dxva since I think hardware deinterlacing looks far better than software.
Any suggestions would be appreciated!
I have been testing some more now and found out that I also get audio/video sync problems when exiting osd if I use ffdshow as mpeg decoder and deinterlace with kernel bob or yadif double frame rate. Using a deinterlace filter with any decoder that combine the fields works though.
So maby it isn't a dxva problem after all ...
Finally I bought a new graphic card: radeon hd2400 pro agp
I now get excellent playback and no stutter when exiting osd even with dxva enabled. ;)
