Resume DVD dialog not showing
Kommakul
Hi
I experience the following problem:
When i have autoplay dvds enabled I see correctly the "dvd inserted do you want to play it" but the following "resume playback" dialog does not show. DVBV freezes in a black picture.
If I right-click the DVBViewer-tab in the windows taskbar, the dialog shows, and i can continue.
Some observations:
The problem only occurs after an autoplay, not if I just start an already inserted dvd
It makes no difference whether its a physical dvd or mounted image
After reading about a similar problem with EVR i have tried different codecs and EVR with no difference. currently im on powerdvd7 and overlay mixer
I have just tried a reinstallation of dvbv
TV-card: Hauppauge HVR-1300 Driver version: 2.121.25351.0
Chipset: Intel® 915 Express Chipset Family
Videocard (Integrated): Intel® 82915G/82910GL/82915GV/82910GL Express Chipset Family Driver version: 6.14.10.4396
Anyone has a solution to my problem?
Or is it a bug?
This is really a problem as my wife is giving up on my htpc, because of this!
Regards
Christian
