Renaming Channel Names
Danjo
Hi there,
I need to know if there is a quick and easy way to do the following in DVBViewer:
a ) Remove the (eng) and (NAR) in the channel names after a scan?
b ) Remove the encrytion tick from all encrypted channels?
c ) Change the AC3 to normal Audio?
Also in your experience what are the best codecs to use for HD?
Thanks
Danjo
Edited by Danjo
