arr Posted April 1, 2009 Posted April 1, 2009 Hello! I had many problems with DVBViewer settings to watch HD channels, until I discovered transedit and now I can findand watch HD channels. But now the problem is bigger and I think I need some help. I am not able to see 422 transmissions (eg. feeds), I can detect the signal, I can hear it, but I cannot see it. It is not a problem with the % of signal, because with qualitv receiver I can see them without any problem. I tried a lot of codecs, but no one seems to work for the images. Anyone could help me, please? Quote
Derrick Posted April 1, 2009 Posted April 1, 2009 ..most video decoders don't work with 422. Get the video decoder from moonlight (elecard), mainconcept (all from the same source) or ffdshow. if you're streaming you could also use vlc. Quote
arr Posted April 1, 2009 Author Posted April 1, 2009 I already tried these three codecs, but they do not show any images. Quote
arr Posted April 1, 2009 Author Posted April 1, 2009 I have no doubts!! But do you know what could be failing? I am a bit lost with this problem!!! Quote
Derrick Posted April 1, 2009 Posted April 1, 2009 ..check whether a suitable decoder is used (view -> filters). Quote
arr Posted April 1, 2009 Author Posted April 1, 2009 Sorry, what do you mean with suitable decoder? I did not change anythingsince I installed the probgram (4.0 pro). How should they be configured? Thanks for your help! Quote
arr Posted April 2, 2009 Author Posted April 2, 2009 Sorry, could you please explain a bit more what do I have to do? I do not know what is support.zip nor where I have to attach it... thanks Quote
Derrick Posted April 2, 2009 Posted April 2, 2009 have a look at the top of this page.. Always follow these instructions. Otherwise no one can - or wants - to help you!. Quote
