robbo1 Posted April 1, 2009 Posted April 1, 2009 Does anyone know of any good software which I can use to remove the adverts and trim my recorded HD video. I currently use videoredo for the standard video and it is excellent, but I can not find anything to use for HD video. Ideally I would like to save the files as .mkv to save space. Any suggestions welcome. Thanks Robbo1 Quote
Lars_MQ Posted April 1, 2009 Posted April 1, 2009 You can try your luck with comskip to mark the commercials and remove them with tools there mentioned. Quote
Conrad. Posted April 2, 2009 Posted April 2, 2009 Does anyone know of any good software which I can use to remove the adverts and trim my recorded HD video. I currently use videoredo for the standard video and it is excellent, but I can not find anything to use for HD video. Ideally I would like to save the files as .mkv to save space. Any suggestions welcome. Thanks Robbo1 Transport Stream Packet Editor (TSPE) will edit MPEG2 or h.264 streams easily. Something like TSRemuxer or eac3to should be able to convert to mkv pretty easily. Quote
