Fer HA Posted April 1, 2009 Posted April 1, 2009 Hello. To forgive my English. I have installed the v4.0 with the card FlyDVB Trio Cardbus. The channels TDT sees them and I change without problems but the channels SAT I have problems when I change, slow a lot of time and it doesn't even leave sometimes the image. Does some special configuration exist for these cards? Thank you A greeting Quote
tobelz Posted April 2, 2009 Posted April 2, 2009 I use the same Card in my notebook. I don't have any problems. Perhaps something else is causing the troubles? Quote
Fer HA Posted April 3, 2009 Author Posted April 3, 2009 Hello. With the software of the card, lifeview DVT, works perfectly. That is the strange thing. It is sometimes left without sign and I have to remove the feeding cable and to put it other time. I have the drivers 2.11.2.1 In a new installation of Windows XP the same thing happens Quote
Fer HA Posted April 5, 2009 Author Posted April 5, 2009 Hello. It already works. In configuration hardware I have disabled everything. I believe that the problem was in "Opening the complete transponder" Quote
