Lars_MQ Posted April 2, 2009 Posted April 2, 2009 In the membersarea -> tools is a new little helper. It enables the Vista/Winodows 7 explorer to show the detailed fileinfo of DVBViewer recordings. It also enables the Windows indexer/search to search through the details. Vista 32bit /Winodows 7 32bit only and TS files only! In the DVBViewer/Recording service you need to enable the fileinfo option. Quote
NikoP Posted April 4, 2009 Posted April 4, 2009 Doesn't work in Vista 64bit EXPECT when using 32bit program with explorer interface(file open dialog). Entries are there but without values Also filename is no longer shown in statusbar for ts files Quote
Lars_MQ Posted April 4, 2009 Author Posted April 4, 2009 Oh well, solved the Problem: Sadly it is for Vista 32bit only... So just deinstall it and don't bother with it anymore. Quote
Fulco Posted February 16, 2010 Posted February 16, 2010 Will there be a 64 bit (Windows 7) version in the future? Quote
Karl Falz Posted August 7, 2010 Posted August 7, 2010 Quite useful! Would be nice if it were available for 64-bit Windows as well. Any plans to provide that? Quote
Lars_MQ Posted August 7, 2010 Author Posted August 7, 2010 No, unfortunatly we don't have a 64 bit compiler... Quote
majstang Posted January 22, 2012 Posted January 22, 2012 No, unfortunatly we don't have a 64 bit compiler... Any plans to get one since Delphi XE2 is released now and it has a full 64-bit compiler and supports Cross-platform development for Windows and Mac? Must be good for business expanding to the Mac market as well and no need to use emulators anymore. Personally i wanna be abled to use RS on a 64-bit windows the same way as on my 32-bit and most importantly utilizing full system memory. When it comes to script friendlyness, lack of 64-bit support for the detailed fileinfo/property tool for Winodows 7 explorer messes up every script dependant on these detailed explorer fileinfo/property. So Windows7 64-bit is a no go so far for me, unfortunately. Hoping things could change soon. Regards majstang Quote
Lars_MQ Posted March 19, 2012 Author Posted March 19, 2012 Aktually there are plans. Version 2.0 will be released shortly. It supports vista/Win 7 32bit and 64bit and additionally can create thumbnails for a lot of videofiles (with the help of ffmpeg) (this can be disabled in the installer). Personally i wanna be abled to use RS on a 64-bit windows the same way as on my 32-bit and most importantly utilizing full system memory. There will be NO 64bit version of the RS in the foreseable future. The same goes for the DVBViewer. There is no need for this (neither programm uses THAT amount of memory) and there are several things, which simply make it impossible. 64 bit applications need 64 bit dlls. So byebye to the plugins, no sqlite support (only 32bit dll available) and the list goes on... We will do some things in 64bit (when it is fitting) and most likely some Mac programs (only on the client side because there is no standard for dvb hardware on apple hardware) and maybe we do some IOS stuff. Quote
majstang Posted March 19, 2012 Posted March 19, 2012 Aktually there are plans. Version 2.0 will be released shortly. It supports vista/Win 7 32bit and 64bit and additionally can create thumbnails for a lot of videofiles (with the help of ffmpeg) (this can be disabled in the installer). Awesome news Recording properties tool supporting 64-bit is the main key for my scripts to work. Yes, i agree porting the whole RS and DVBViewer to 64-bit isnt entirely necessary right now. This should be a slow process in som alfa version giving the plugin-authors a chance to catch up...vital tools (sqlite) not supporting 64-bit is worse to tackle. Intresting stuff you are letting us know here. I suppose this means you have now made a big investment in Delphi XE2, which not only opens up quite cool possibilities, but supposedly also means now is the time to support the DVBViewer project more than ever...buying a couple of additional licenses Quote
Lars_MQ Posted March 21, 2012 Author Posted March 21, 2012 The next generation is up for testing here: http://www.DVBViewer.tv/forum/topic/48856-DVBViewer-recording-properties/page__pid__360196 Quote
majstang Posted March 24, 2012 Posted March 24, 2012 (edited) Decided to test version 2.0 more extensively today on my Windows 7 64-bit system and i have to say the results are somewhat shaky. 5 recordings were made by the RS two H.264 and three MPEG2 (.ts). Both H.264 had no "Data rate" value or more precise 0. Two MPEG2:s had all details there, but one had pretty much everything missing under "Video" section. Edited March 24, 2012 by majstang Quote
