WeBServer
Balle
Running WinXP with DVBViewer Pro ver. 4. When I try to press the Icon for WEBServer (ver 1.50) It wont start. I'm planning to run TV to my old XBOX with UPnP. I've also tried to install DVBViewer Recording service ver. 1.4.7.90 (this so I can run UPnP) the Icon in my tray is grey, and I cannot start the service (I see that I'm missing svcctrl.dll in my plugin folder).
Any suggestions why my WEBServer wont start?
Where can I download the correct svcctrl.dll file that will work with
1. The webserver does not do UPnP.
2. You don't need the svcctrl.dll for the 1.4.7.90.
3. Did you install the 1.4.7.10 recording service first as it is said in the readme?
3. If you mean the readme (readme_svc.html) it says you need a working 1.4.7.10 installation. I could not find this, so I just put all the files in the DVBViewer directory. Where can I find ver. 1.4.7.10, and is there an executable file or how do I install?
where you got the other files from. the membersarea of course.
I've found and installed ver. 1.4.7.10. But when I try to enter the WEB Interface (and use the default user/password admin/admin) I get the message "template not prepared"
suggestions?
Sorry for the last post, Still wondering if anyone can answer why I get the message "template not prepared" in iexplorer.
I think there is tome thing wrong with your SVCweb folder.
Rename it an reinstall the recording service.
