Sky Italy HD and Dbviewer
thecaptain2000
I have a Vista 64 htpc built using an Hauppauge HVR-4000, Wintv-CI and a T-rex 4.6. I have a SKY Italia Subscription, including the HD channels. I can see with no problems SD channels but I have a bizarre behavior with SKY HD content.
I can see with no problems SKY HD Cinema +24 channel
I cannot see any other SKY HD channel but the CI menu reports the card is decoding OK.
I have tried most H.264 codecs: Cyberlink, Microsoft, Intervideo and CoreAVC codec.
With all these codecs Sky cinema HD +24 works well
In relation to any other channel, I get a dark screen. Using the CoreAVC codec, I can see something but the image is FAR from perfect. I would say it is by 40% rendered correctly whether the remaining 60% is made of noise.
am not posting this in here because I am not so sure it is a DVBViewer bug, actually it could be anyhting: proprietary codec used by SKY Italy? imperfect NDS emulation by the T-Rex? the Wintv-CI not working? Codec problem? maybe me missing some piece of information?
If anybody has any piece of useful information please get intouch. If you need to do it privately my email address is rdallarmi at gmail com
regards
Renato Dall'Armi
can't really answer you question but I thought the win-CI did'nt work with sky and DVBViewer,seems I'm wrong though? has sky Italia not sent out new sub cards to you? I know we in the uk are expecting new cards from sky and the rumour is NDS emulation has changed slightly.Be interested if anyone knows more as the waiting for a new sky card(too make sure my cam still works) is what is stopping me getting sky hd just yet.BTW I have also a nova S2 card(as well as a floppydtv s2) and found the arcsoft codec to be perfect,I'm guessing codecs are not your problem though.
Hi, no I did not receive any new card so I have to believe that is just a rumor. I do not believe it is a decoding problem, I can confirm however that wintv-ci and sky sd do work, the problem is to have it working with sky HD (minus sky cinema hd +24 that already does work)
  • 5 months later...
Hi, did you solve this problem? Please post how you solved it.
Thanks
