Przemek211 Posted April 4, 2009 Posted April 4, 2009 (edited) hi, if i'm using any skins downloaded from forum (also new-def 16:9) i have problem: often channels in anamorfic 16:9 not using full screen. Look here: http://img3.imageshack.us/img3/1232/beztytuumpq.jpg picture is deformed. If i'm using pre-installed skin (default) picture on all channels is ok.I change now Arcsoft codecs for MPEG2 to microsoft codec and still working. So this first problem is probably resolved I have also second problem. This is on all skins. Sometimes OSD isn't started. If i change channel i don't see nether panel. If i click Esc also don't start menu and not working volume changer in scroll. i have a newest version of DVBViewer downloaded from members section. Works on Vista Home premium with all new updates. My PC conf is: P4 2,6GHz, 1GB RAM, HD2600XT on AGP. I'm using Arcsoft codecs for video (MPEG2 and h.264 with DxVA support) Edited April 4, 2009 by Przemek211 Quote
Przemek211 Posted April 4, 2009 Author Posted April 4, 2009 (edited) ///And third (actually second) problem. If i have a two satellites config (astra + hotbird). If i open program on hotbird and next go to astra channels, DVBV view a 15% of quality signal and not view a channel. If i close program on astra, on next open all is ok. (go from astra to hb is ok, but if again go to astra i have the same problem). i have a skystar s2 with a newest bda driver Edited April 4, 2009 by Przemek211 Quote
Przemek211 Posted April 5, 2009 Author Posted April 5, 2009 (edited) more than fifty views and no reply? Sorry for triple post, but Edit mode is deactivated after few minutes. And i have third (the biggest) problem. On FTA HD DVB-S(2) channels from Astra, all is good. But on hotbird only HD DVB-S FTA is ok. HD DVB-S2 is no video and audio, but signal is still ok. (beetwen 78-80% and on astra is similar) Sometimes, for approximatelly 500ms i hear sound. i using EVR + Arcsoft (for test i install powerdvd 9) this is most important problem for me and please help me support.zip Edited April 5, 2009 by Przemek211 Quote
