rockhoggle Posted April 6, 2009 Posted April 6, 2009 Using the Blackgold BG 3540 2x satelite inputs, problem exists with version 0.25,0.39,0.49 of the BG driver. Cyberlink Test Kit works with no crashes so problem appears to be within DVBViewer. Support.zip enclosed. Any help appreciated. support.zip Quote
Lars_MQ Posted April 6, 2009 Posted April 6, 2009 Just deinstall it and reinstall it, using this time the userdata/passwort excactly as you received them.. Quote
rockhoggle Posted April 6, 2009 Author Posted April 6, 2009 Just deinstall it and reinstall it, using this time the userdata/passwort excactly as you received them.. This issue isn't relating to the username/password entry. The program functions for 3 minutes. I can watch channels, go to options, scan for channels, etc....... but it closes after 3 minutes. Forigve me if I am wrong but the username password box not having the right info would simply shut the program down straight away. Quote
rockhoggle Posted April 28, 2009 Author Posted April 28, 2009 This issue isn't relating to the username/password entry. The program functions for 3 minutes. I can watch channels, go to options, scan for channels, etc....... but it closes after 3 minutes. Forigve me if I am wrong but the username password box not having the right info would simply shut the program down straight away. Bouncing this as I still have no solution to this problem. Someone please help. Quote
Lars_MQ Posted April 28, 2009 Posted April 28, 2009 Just deinstall it and reinstall it, using this time the userdata/passwort excactly as you received them.. Quote
