How to make Technisat TTS35AI remote work with DVBviewer
Hello I just purchased a Technisat Skystar HD2 and cant get the included TTS35AI remote to work with DVBViewer, i use Winlirc and follow the steps i found in this guide but I never get step 1h) to work. I have tried all com ports but think its not a com as the infrared receiver has a 2.5m jack to the Skystar Card.
does anyone have this setup working? Thanks
http://winlirc.sourceforge.net/ (August 17, 2003 ver 0.6.5)
You can also here find good trouble shooting suggestions.
For some screenshots of winlirc se here
http://sourceforge.net/project/screenshots...?group_id=22987
------start of winlirc install---------
1a) Unzip and copy the winlirc.exe to the DVBViewer folder.
1b) Close all programs and start winlirc.exe
1c) If winlirc is startet for the first time you will get an errormessage (click OK).
Select Configure or Reconfigure
IMPORTANT: Don't click the Learn button!!!!!!!!!!!!
1d) In Config field browse to the technisat.cf file (In DVBViewer folder)
1e) Choose the correct COM port, if you know
1f) Click Anylyze button. Hopefully this is succesfully
1g) Click The Raw Codes button
1h) Click some buttons on the remote. If text and numbers are displayed,
you are connected! Close the window.
1i) If 1h) failed, try another COM port, then goto 1g)
1j) Click OK button, Then wait a bit and Click Hide button
---------end of winlirc install-----------------
2) Copy The Technisat.remote file to the DVBViewer\Remotes folder
3) [Close and] start DVBViewer
4) Settings -> Options -> Input -> Inputplugins
5) Check WinLirc, click Apply button
6) Settings -> Options -> Input
7) Click Load button and select the Technisat.Remote file
8) Click Apply button, and you are done.
Start the OSD with MENU key
