realtime multitasking
Griga
Realtime multitasking... that's a feature some digital video recorders provide. It means you can record TV and simultaniously watch another video from harddisc.
When I open a video with the DVBViewer, recording stops automaticly. But with Marfis renderer the DVBViewer is capable of timeshifting, which already is a kind of realtime multitasking... so probably the step to the above mentioned feature isn't very big. Think about it, Christian!
To everybody reading this: have a good day! (That's a command - you have no choice :) )
Griga
Guest Michael
hmmm you can open your media player and watch your movie with that program....
another thing is that you can use my pvr tool.... it records with the recorder.exe with a cpu usage of 2%.... then you can use DVBViewer to watch your movies while the pvr records...
  • 3 years later...
Hello Griga,
Christian and you thought about it...
GREAT WORK!!!
Torben
@Torben: Was soll das? Was holst du solche alten Themen wieder raus? Willst du damit Leute verwirren, indem sie anfangen die alten Infos als aktuell zu betrachten?
Thema hiermit geschlossen, weil 1219 Tage alt. :bounce:
