DiSEqC raw commands..help req
ITS A SCAM !
Can anyone please tell me what these raw commands are ?? And what do they do ?? Also will they help my PC move the dish automatically to the correct satellite when i select it with DVBViewer...
Working with DiSEqC raw commands resp. the DVBViewer Pro 4.0 DiSEqC Editor requires profound knowledge of the Eutelsat DiSEqC specifications - very technical, very complicated. Too difficult for you, I'd say.
That's why we switched over to a more comprehensible type of DiSEqC editor, as provided by the current DVBViewer Pro Beta and TransEdit 3.3. It is described extensively in the TransEdit Manual. That's all we can do for you.
Thank you for the reply, I do not even TransEdit....but that is something to think about another day...lol
