Enabling SRT subtitles from OSD
uglyned
First of all - please forgive me I don't know too much about subtitles.
I have several AVi files, each with corresponding srt files of the same name. I can make DVBViewer disable them through the Settings menu, then Subtitle then selecting Stream[0].
What I would like to be able to do is select and enable the subtitles through the OSD but the subtitle button doesn't seem to work on my remote control. It does work for DVB or teletext subtitles while watching live TV or recorded DVB programmes but not on converted AVI files, even while the corresponding srt file is present and it works using the mouse.
Is there any way of enabling accompanying srt files using the OSD instead of the mouse?
Thanks!
