CX23882-19 Posted April 13, 2009 Posted April 13, 2009 Can we please have a menu item or button that will allow us to enable the "Keep timeshift file" option as on a one-off basis? On occasion there will be something that I want to keep so I enable this, but I then forget to disable it and result in many timeshift buffers saved to disk. Quote
uglyned Posted April 13, 2009 Posted April 13, 2009 Seconded. Also, in the OSD would be nice - don't want to use a mouse on my HTPC. Quote
MartinSat Posted May 7, 2009 Posted May 7, 2009 I second this to, I never want to save all time-shift files, only the ones that I want to see it back later or show it to an other family member. So an option in the OSD menu (or a special button) to keep only the current time-shift file and in the settings the one that does it for all time-shift file. Maybe it can it even be done by a plugin that turns the "Keep time-shift" off if its on after a "channel switch" or "time-shift off" event. Quote
