majinbu Posted April 13, 2009 Posted April 13, 2009 (edited) Hi to everyone! Is there any way to embed television on my web site? I mean, can DVBViewer help me in that? Thanks, Stefano. Edited April 13, 2009 by majinbu Quote
Tjod Posted April 13, 2009 Posted April 13, 2009 As the first thigh you should make sure that it is allowed to share the television program on your web site. Than install VLC Player 0.8.6i and the Web Interface 1.5 (Members Section) or the Recording Service (Members Section). On both Web Interfaces is the possibility to stream. But thy are designed for a secure environment, like a private network and not for the www. So security would be a problem if you use them direct. Quote
Lars_MQ Posted April 13, 2009 Posted April 13, 2009 Just don't do it. It's illegal (think copyright), you server can not handle hundrets of realtime transcodings so just dump this idea. Quote
majinbu Posted April 14, 2009 Author Posted April 14, 2009 Just don't do it. It's illegal (think copyright), you server can not handle hundrets of realtime transcodings so just dump this idea. @Tjod and @Lars_MQ first off, I say many thanks for the replays to both of you. What I'm thinking by my self is that my wishes are little bit too hard to manage...so I'll give up with them. Thanks the same! Stefano. Quote
