Reza Sadeghi Posted April 13, 2009 Posted April 13, 2009 I am now using Registered DVBViewer 4.0.0 Pro. whenever i want to use it in client mode with DVBVoewer Pro Server on another PC there is not any Unicast Network Device / Multicast Network Device on Hardware settings. so i can not use DVBViewer 4.0.0 Pro as Client to watch TV from the Server. there is just Technisat UDST7000BDA DVB-S Tuner for my own Technisat Skystar USB 2 HD CI. I was able to use DVBViewer as Client/Server in Version 3.8 and both Unicast/Multicast Network Device was availabe beside Technisat UDST7000BDA. could you please solve this problem? Quote
Reza Sadeghi Posted April 13, 2009 Author Posted April 13, 2009 (edited) sorry forgot attach my Support.zip file. here it is my Support.zip Edited April 13, 2009 by Reza Sadeghi Quote
Supertonic Posted April 14, 2009 Posted April 14, 2009 Open the usermode.ini in the install folder of the DVBViewer with a texteditor and change 'unicast = 0' to 'unicast=1'. Save the file, open the program, now you should see under settings-> options -> hardware also unicast network device Quote
Reza Sadeghi Posted April 14, 2009 Author Posted April 14, 2009 Yes. and by after Scanning Device on Hardware settings it has worked. now i can use DVBViewer 4.0.0 Pro as client/server too. Big Thanks for your answer. Quote
