Reza Sadeghi Posted April 13, 2009 Posted April 13, 2009 I am using Registered DVBViewer 4.0.0 Pro. before using 4.0.0 in DVBViewer 3.8 there is a sticky feature in DVBViewer. in this feature whenever i Drag DVBViewer window to near corner of Windows (for example drag DVBViewer from center of screen to near of Taskbar showing Time area) DVBViewer was stick completely to time area and there is not any effort to put the DVBViewer in proper section of the screen. but in this new 4.0.0 Pro this feature does not work correctly in DVBViewer window but it is work in DVBViewer main window and the Channel List. when you use DVBViewer in zoon mode (50% or 25% .... ) and drag channel list near of DVBViewer screen , channel list will stick to DVBViewer window. this feature is wonderful but i need it same as DVBViewer 3.8 could you please solve this problem? Quote
Reza Sadeghi Posted April 13, 2009 Author Posted April 13, 2009 sorry forgot attach my Support.zip file. here it is my Support.zip Quote
Reza Sadeghi Posted April 14, 2009 Author Posted April 14, 2009 because i could not edit my last posts : my Support.zip attached in this Topic. Quote
antielvis Posted April 15, 2009 Posted April 15, 2009 (edited) Edited April 15, 2009 by antielvis Quote
Reza Sadeghi Posted April 17, 2009 Author Posted April 17, 2009 antielvis... What ? do you have any suggestion or solution? Quote
