gucky Posted February 12, 2004 Posted February 12, 2004 hallo, besteht die möglichkeit dem viewer das TS format als natives format beizubringen? besteht die möglichkeit die einträge in der recordliste nicht BEI der aufnahme zu löschne, sondern erst HINTERHER? danke gucky Quote
Klausing Posted February 12, 2004 Posted February 12, 2004 You can record in TS with the VR-Plugin. IN R3 you make timed recordings with this plugin. Change only from Record to VR-Plugin in your PVR. In Plugin you set TS as default and save settings. Thats all. Now you record a programmed film as TS format. Steffen Quote
gucky Posted February 12, 2004 Author Posted February 12, 2004 sorry for the german posting.will will test it. thanks gucky Quote
Griga Posted February 12, 2004 Posted February 12, 2004 IN R3 you make timed recordings with this plugin. Change only from Record to VR-Plugin in your PVR. No, sorry - doesn't work yet. As I've already mentioned here, this way of programming timer recordings for the VR plugin will be supported in the *next* plugin release. Till then it has do be done in the old way, which I've described in this thread. Griga Quote
