Skystar 2 TV Remote and DVBViewer Pro 4.0
Sheperson
Maybe this is not the best place to post this, so forgive me!
Recently I got a Skystar 2 TV and DVBViewer Pro 4.0. I have problem using the remote control with DVBViewer Pro.
The remote is TS35 one and it works perfectly with DVBViewer TE supplied with the package.
Here are my configuration settings for WinLIRC (the default ones):
WinLirc Host: localhost
Port: 8765
Key Delay: 150 ms
Repeat Delay: 350ms.
Does anyone know how to get it up running?
Thanks in advance.
I solved my problem. It was because my firewall blocked DVBViewer from accessing the WinLirc server!
