yavuz Posted April 19, 2009 Posted April 19, 2009 Hi there, When hitting the keyboard shortcut for Favourite station minus/plus I go to the previous/next channel in the first favourites list the channel is found in. When a channel is in multiple favourites list this is really not as expected. Example: Favourites tree: - Folder A -- Channel A -- Channel B -- Channel C -- Channel D - Folder B -- Channel C -- Channel X -- Channel Z If I select (through the OSD Favourites list) Channel C in Folder B, and then hit Favourite station plus DVBViewer will change to Channel D instead of Channel X. support.zip Quote
yavuz Posted April 24, 2009 Author Posted April 24, 2009 Bump. And? Is this confirmed? Will this be fixed in next version? Quote
Lars_MQ Posted April 24, 2009 Posted April 24, 2009 The IDs are identical if a channel is duplicated in the favourites, so the system takes the first found ID. So yes there might be something to fix in one of the next version, which will prevent duplicate entries. Quote
