byfly Posted April 20, 2009 Posted April 20, 2009 What is the correct way to setup the controls for PowerDVD with the DVBViewer Switch? I don't get any controls sent to PowerDVD. I have configured DVBV with keyboard shortcuts, which are sent by iMon. These shortcuts work fine in DVBV: stop, play, pause... But these controls are not received by PowerDVD. I think I have configured the switch correctly. It's stated in the instructions that the controls are read from the default.remote. I assume that this is from the DVBV settings folder(?). I did save my key settings over the default default.remote. I have also enabled the Connect control option and also tried it with the keyboard hook. What's wrong? What should I try next? Thanks! -byfly Quote
Tüftler Posted April 21, 2009 Posted April 21, 2009 I think the problem is the iMon-Software. These can only receive keyboard shortcuts of software which is actually in foreground (active). So you must set these specially keyboard shortcuts for PDVD in the iMonManager itself. Quote
byfly Posted April 21, 2009 Author Posted April 21, 2009 Thanks for the reply. I didn't realize that I could do it that way. Althought it was quite obvious. Now I can control PowerDVD also! Quote
