stsa Posted April 20, 2009 Posted April 20, 2009 Hi, I'm using the latest beta of recording service and it works fine so far. Have a question since my kid wants to wath TV on his Xbox if it's possibel to run both Vista Media Center and the recording service at the same time ? Have tried but with no success and want to know if it's possible or not. For myself I'm using Popcorn A110 to watch TV from the Recording Service. I have two FireDTV DVB-C on the same machine with different channels on those two cards. One for Media Center and the other one for recording server (Only one card is set to normal) Regards Stsa
Lars_MQ Posted April 20, 2009 Posted April 20, 2009 If VMC and the service don't try to use the same card there should be no problem running them both at the same time. The service does not interfere at all with VMC.
stsa Posted April 20, 2009 Author Posted April 20, 2009 If VMC and the service don't try to use the same card there should be no problem running them both at the same time. The service does not interfere at all with VMC. Hi, Thank for your answer Had to install both cards in VMC and then disable the one I didn't want in the registry. Now I can watch from Linksys DMA2200 and Xbox to the first Card and at the same time watch paychannels on the other tv-card. GREAT GREAT
