andre123 Posted April 22, 2009 Posted April 22, 2009 Hello How can use the Philips RC 197 remote control with DVBViewer pro. Thanks Andre 1 Quote
Gioxy Posted April 22, 2009 Posted April 22, 2009 (edited) What kind of remote receiver you've got? USB, serial or...? And: have you got some sw with it? Edited April 22, 2009 by Gioxy Quote
andre123 Posted April 23, 2009 Author Posted April 23, 2009 What kind of remote receiver you've got? USB, serial or...?And: have you got some sw with it? Hello I have irtans and i have signal but wat next? Thanks Quote
Gioxy Posted April 23, 2009 Posted April 23, 2009 (...please always replay to all question as there are IRTrans USB, serial and even ethernet...) I dunno how IRTrans communicate with PC, but I can guess via a propetary sw, so the first step is to familiarize with it... On the other hand, to rule out the DVBViewer part, you have to: • go in "Settings / Options / Input" window • press "Learn" - select a DVBViewer action - press the relative remote button - (repeat the two step above for all buttons you need) • unpress "learn" • close the "Option" window... Hope that's of any help; otherwise feel free to ask for more, but please be more explanatory cause my cristall ball is irremediably broken Quote
andre123 Posted April 24, 2009 Author Posted April 24, 2009 I try it but when i puch channel one i get channel 12 and when i puch channel 3 i get channel 4 enz something is wrong do you no what i'm doing wrong. Gr Andre Quote
Gioxy Posted April 24, 2009 Posted April 24, 2009 What do you want to command with the remote number? The channel as they are numbered in the channel list or the favourites? When you have to choose one of them, you can: - link the number remote buttons to the number of the relative section - link the number in the other section and add this tweak to the "setup.xml" you find in "About / Configuration folder": ----------------------- Value: UseFav Section: Input Accepted: 0 (false), 1 (True) Default 0 Description: Determinates if the favorites are tuned up/down instead of the channels if the osd-up/-down key is pressed. ----------------------- You can find other useful tweaks in the "Tweaks.txt" file located in the main DVBViewer folder... Quote
andre123 Posted April 25, 2009 Author Posted April 25, 2009 What do you want to command with the remote number?The channel as they are numbered in the channel list or the favourites? When you have to choose one of them, you can: - link the number remote buttons to the number of the relative section - link the number in the other section and add this tweak to the "setup.xml" you find in "About / Configuration folder": ----------------------- Value: UseFav Section: Input Accepted: 0 (false), 1 (True) Default 0 Description: Determinates if the favorites are tuned up/down instead of the channels if the osd-up/-down key is pressed. ----------------------- You can find other useful tweaks in the "Tweaks.txt" file located in the main DVBViewer folder... Thank you very much gr Andre Quote
