Cause of failing iso mount identified
Kommakul
Hi
I think I have identified why DVBV can't mount isos:
The unmount and mount command is fired 'simultaneously', while it is necessary to first fire the unmount command, wait for completion and then send the mount command.
Now it is identified could you please correct it?
And I'm still missing a report regarding these reports:
Can't select between multiple DVD drives
and
Resume dialog not showing
Regards
Christian
Hi
and
Regards
Christian
See here, looks like it will be fixed in new release.
