slashes Posted April 27, 2009 Posted April 27, 2009 Hi, I would like to know how I could change the channel number ? In my channel list, I have the channel 'TF1' which have the number 29, and I would like to set it to 1 (as it is in France). Currently I have defined favourites list (and set channel 'TF1' at the first position), in order to correctly sort the channels as I want (and as it is defined in France), but when I open the EPG, the channel are not sorted correctly. Any idea to do it ? Thanks in advance Quote
Devastation Posted April 30, 2009 Posted April 30, 2009 I would like to know how I could change the channel number ?In my channel list, I have the channel 'TF1' which have the number 29, and I would like to set it to 1 (as it is in France). The way I know to do this is to sort the channels with the channel editor in the way you want it. Note: channels start with number 0 for the first channel, so put TF1 at the second position in channel list and it will have the number one. Quote
Lincoln_DJ Posted May 3, 2009 Posted May 3, 2009 just thought i'd addthat when you open the challellist editor, you simply drag the channels around in the order you want them. i moved them all into one folder first, made it easier on the eye for me... Quote
