Problems scanning transponders with DVBViewer - Hauppauge WinTV HVR400
decoded
Hello,
I've problems when scan transponders in DVBViewer, specially with DVB-S2 signals.
When I scan with transedit, this found 267 channels (in Eurobird 9A) however, when I scan with DVBViewer only found 56 channels.
My hardware is Hauppauge WinTV HVR4000 DVB-T/DVB-S/DVB-S2/AnalogTV/FM with version 2.123.27056.0 / date 25/02/2009
I created the file support and uploaded.
Thanks for your responses.
And where is your problem? When "TransEdit" founds all channels its ok, use its list in DVBViewer, for me, TransEdit is zhe program to scan and find channela and make lists, DVBViewer is for viewing the channels, use the "ini" found and saved by TransEdit and import it in DVBViewer.
PeterF
Yes. I tried to tune into TransEdit and send the channels found to DVBViewer but when I try viewing channels in DVBViewer are not watch.
ok, you saved the list in Transedit, then open DVBViewer in Menu go to Channel, to Channel-Editor, in this window at the left side is a list with your sats, there you can import with "Ctrl+I" your list from Transedit, ev. you must search for the right directory where you saved it from Transedit. When this is done, it was all, you have all channels found with transedit now in DVBViewer an you can watch it.
PeterF
Yes. I've done that, I get the channels found in DVBViewer with TransEdit but not displayed. In TransEdit I can view them by clicking 'preview'.
in DVBViewer in "Options" under "Hardware", have you checket "is DVB-S2 Device",
PeterF
Hello, thanks for your responses.
The error is that I have active 'LNB sharing'.
Now all run perfect!
Thanks and sorry...
