xkodi Posted May 1, 2009 Posted May 1, 2009 i have TBS8920 DVB-S2 card and TransEdit 3.2.6 works just fine, but all 3.3.x versions can't scan and "Analyze" button is not active, here is screenshot: if i need to provide some additional information, please, let me know, thank you! Quote
Griga Posted May 1, 2009 Posted May 1, 2009 "Analyze" button is not active Most likely because DVBViewer Pro or GE is not installed on your PC, or TransEdit doesn't recognize a valid installation. additional information Attached TransEdit.ini (see Info -> Configuration Folder). Quote
xkodi Posted May 1, 2009 Author Posted May 1, 2009 (edited) Most likely because DVBViewer Pro or GE is not installed on your PC, or TransEdit doesn't recognize a valid installation. usually, i use TransEdit only and indeed DVBViewer isn't installed on my PC, but after i installed it, everything is back to normal, thank you! so, the problem is solved and from now on i will know that proper installation of DVBViewer is required in order to use TransEdit. Edited May 1, 2009 by xkodi Quote
