jakeh Posted May 3, 2009 Posted May 3, 2009 I would be great if you could add an option to recording options or a tweak for one touch record scheduling in OSD. I would work like in EPG window button "Send to PVR" when you select Record in OSD. In cases when adding recordings from OSD EPG / OSD Timeline without need to change the default recording settings you always have to close the dialog by accepting the default settings. Quote
jakeh Posted November 27, 2009 Author Posted November 27, 2009 This new feature by using tweak seems to be included in the latest beta according the release notes. This will increase every day usability greatly. Sincere thanks to the development team. You have definitely earned it. Quote
jakeh Posted October 22, 2010 Author Posted October 22, 2010 In the 4.5 changelog: "Add: OSD: The record Button does add or delete a timer on the following OSD pages: EPG-Now, Timeline, Channellist, EPG-Search, EPG-Details, EPG-Channels. The confirmation can be disabled (see tweaks.txt)." Could you give more information how exactly I can disable the recording settings confirmation dialog, please. So that I can add timer by one button press in OSD page. I can't find this information from tweaks.txt Quote
tpaasiala Posted November 9, 2010 Posted November 9, 2010 Could you give more information how exactly I can disable the recording settings confirmation dialog, please. So that I can add timer by one button press in OSD page. I can't find this information from tweaks.txt I'm missing this information too. This is not mentioned in tweaks.txt. I also seached setup.xml but i could not find such option. Quote
jakeh Posted January 23, 2011 Author Posted January 23, 2011 In the 4.5 changelog: "Add: OSD: The record Button does add or delete a timer on the following OSD pages: EPG-Now, Timeline, Channellist, EPG-Search, EPG-Details, EPG-Channels. The confirmation can be disabled (see tweaks.txt)." Could you give more information how exactly I can disable the recording settings confirmation dialog, please. So that I can add timer by one button press in OSD page. I can't find this information from tweaks.txt There is a tweak to disable delete timer confirmation: http://de.DVBViewer.tv/wiki/Tweaks.txt#askdeletetimer Disabling delete timer is half of the OSD one touch recording solution. Usability of adding timer from OSD EPG would be superb if timer dialog could be disabled. Now when adding timer it is normally useless to confirm the default timer settings. Would it be possible to add a tweak to disable OSD add timer (recording settings) dialog, please? Does this tweak already exist (as hidden maybe), could we get comment from developers, please? Quote
