OSD Teletext page selection fails in certain case
OSD Teletext (which is by the way great) has one issue.
The page selection fails when reading the teletext pages to the memory is still in under way. If you wait the page to come it will not be selected and you have to make the page selection again.
So this issue is quite annoying after channel change when you have to wait a while before making a page selection in OSD Teletext to get page reliably by one selection.
I'm using DVBViewer 4.0. This has been an issue also in previous versions.
Confirmed. Also in the current beta it doesn't work like it should.
Noted, but doesn't seem like a bug, I'll take a look at it after the next release.
  • 3 months later...
Hi Lars,
Have you got time to look this issue.
In the 4.2.1 version OSD Teletext improvement: always 4:3 improved usability a lot. When using large 16:9 screen it is now much easier for eyes to focus to whole page :)
This page selection issue is still bothering me so I have high hopes that this could be fixed soon.
After the improvement usability would be superb. This feature is de-facto among teletext solutions.
Here in Finland Teletext is still widely used and specially among sports fans :o
  • 4 months later...
Hello, Finland calling
I have not tested beta versions but do you have this bug / enhancement in DVBViewer roadmap?
Could someone among developers give some information about progress of looking this issue, please.
You are doing great work!
Everyday fan of DVBViewer :)
  • 9 months later...
Hello,
I can confirm this is still an issue in 4.5 version.
Sorry that I am repeating myself. This page selection issue is still bothering me. Page should be selected by entering page number only once in every case.
Could you fix this, please.
One addition to previous message.
I would like to inform cosmetic bug regarding new teletext engine in 4.5 version. On the left side of the OSD Teletext window there is unnecessary black vertical line/border which was not present in previous implementation.
We had to make it fully visible due to user complaints. Usually the leftmost of the 40 teletext columns is used for a (spacing) control code that sets the line color. However, on few teletext pages the text begins in the first column with default line colors (white on black), thus being cut off in previous DVBViewer versions.
Thanks for the information and clarification. Good that now there is no possibility for cut off.
Maybe one black column could be added also to the right side also to keep balance in visual experience?
Now visual implementation looks a little bit unfinished.
  • 2 months later...
Hello,
This is still an issue in 4.6 and maybe forgotten.
Suggestion: Would it be possible to add to teletext engine a checkup functionality which would be executed when all the pages have been read to memory after channel change. The functionality would simply check if the page has been selected and if so then switch to the page.
How about Griga, is it feasible? :unsure:
It works in the teletext window, as you can see. Is it caused by the teletext handling in the DVBViewer Pro OSD, not by the underlying teletext engine. So it must be fixed in the OSD. And yes, I think it has been forgotten. I'll add it to the internal bug reports.
Hi everybody
I can confirm also OSD Teletext not work in 4.6
I have 2 harddisk in my HTPC
1 DVBViewer 4.5 and OSD Teletext works fine
2 DVBViewer 4.6 installed yesterday and OSD Teletext not work
We will waiting for the fix
Thanks in advance
