uglyned Posted May 4, 2009 Posted May 4, 2009 Hi, Try as I might ai can't work out how to do this! If I put PiP on and change channel, the main window changes channel and the inset window stays the same. Is it possible to change the channel in the preview? If so how do I do it? Thanks for your help! Quote
Lars_MQ Posted May 4, 2009 Posted May 4, 2009 you can swap channels with OSD-Green (F6 in the default). Quote
uglyned Posted May 4, 2009 Author Posted May 4, 2009 Thanks Lars. I must have something wrong with my control setup as it jumps back 10sec when I press green or F6. Will try to work it out. Quote
