Blue Fishey Posted May 5, 2009 Posted May 5, 2009 Morning Just updated to 4.1 from 4.0 The option has gone from the Scan Channels Angular Pos. ???? Do you just put in 1 then change to W or 19.2 change to E ??? Blue Quote
Tjod Posted May 5, 2009 Posted May 5, 2009 Did you read the changelog? DiSEqC 1.1/1.2 New: Completely rewritten DiSEqC 1.1 / 1.2 support (only for DVB-S devices allowing to send DiSEqC raw commands), which means support for motorized dishes and cascaded DiSEqC elements (uncommitted switches, positioner behind a switch). All thanks to griga. New: DiSEqC Editor ("DiSEqC expert mode"). Allows to assign user-defined DiSEqC command sequences to a satellite position - as you will see - much more conveniently than with the DiSEqC Editor of DVBViewer Pro 4.0.0.0 and earlier versions. Removed: Positioner Console, please use Transedit 3.3+ for this. It is much better suited.For details please read the DiSEqC instructions:http://www.DVBViewer.com/griga/TransEdit%20E/DiSEqC.html http://www.DVBViewer.info/forum/index.php?showtopic=33795 Quote
Blue Fishey Posted May 5, 2009 Author Posted May 5, 2009 morning Yes The question still stands do i just put the degree value in the Angular Pos. Box ? Blue Quote
Blue Fishey Posted May 5, 2009 Author Posted May 5, 2009 sorted Choose the transponder list and fills it out so just put the degree;s in bay hand if u want to do a blind scan Blue Quote
brildi Posted May 5, 2009 Posted May 5, 2009 Friends, who so to make ???? Will they really it is possible so fundamental change options of DiSEqC and Positioner ???? I use command-strings, I have 40 satellites, what 6000 channels. I must by hand put new specific-settings of DiSEqC and Positioner for all 6000 channels or delete all channesl and scan again 40 satellites???? I not happen scan again 40 satellites !!!! Why you don’t think about users, what have big DB satellites and channels ????? Quote
Griga Posted May 5, 2009 Posted May 5, 2009 I must by hand put new specific-settings of DiSEqC and Positioner for all 6000 channels or delete all channesl and scan again 40 satellites???? Of course not. Reconfigure the DiSEqC settings for each root folder in the channellist editor representing a satellite position (according to the hints for DVBViewer Pro in the TransEdit manual). This will automatically update the contained channels. Quote
