Nimloth Posted May 5, 2009 Posted May 5, 2009 There seems to be problem with Favourites. In my current list I had same channels in few groups From DVBViewer 4.1 channel is present only in 1st Favourites group - in others it's not displayed (even if it exists in favourites.xml) Also I can't add same channel to 2 or more groups in favourites. <section name="2"> <entry name="Header">Telewizja na karte</entry> <entry name="0">1559436586|Disney Channel (pol)</entry> <entry name="1">1118322108|n Sport</entry> <entry name="2">1117666747|Religia.TV</entry> <entry name="3">1116344535|TVN</entry> <entry name="4">1116999896|TVN 24 (pol)</entry> <entry name="5">1123553506|TVN CNBC Biznes</entry> <entry name="6">1080562675|TVN LINGUA</entry> <entry name="7">1120932062|TVN METEO</entry> <entry name="8">1117655257|TVN Siedem</entry> <entry name="9">1122242784|TVN Style</entry> <entry name="10">1121587423|TVN TURBO</entry> <entry name="11">1116356025|TVN Warszawa</entry> <entry name="12">1080562375|TVP 1</entry> <entry name="13">1080824520|TVP 2</entry> <entry name="14">1081349110|TVP INFO</entry> <entry name="15">1157173825|TVP Sport</entry> </section> Example in attached screen Please check attached files support.zip favourites.xml Quote
Tjod Posted May 5, 2009 Posted May 5, 2009 not a bug, this is necessary to solve a problem an make some other changes possible [*]Change: Favorites: From now on there are no duplicate entries of channels with the same ChannelID in the favorites list allowed. They collided with the fav+/- function. Existing duplicates will be removed. http://www.DVBViewer.info/forum/index.php?showtopic=33795 Quote
