Quicker DVBT scan
bigaluk
I created the following text in a file called DVBT_Mendip.ini and saved it to the Transponders subfolder of the (important) Configuration Folder. This is the folder you get to by clicking the "Show Configuration Folder" link on the Options dialog.
As a result, scans of DVBT speed up like a bat out of hell. Well worth doing. If like me you are in the UK Mendip area, you can copy the content below exactly. Other areas - look up the freeview transmitter info on the web, http://www.ukfree.tv/starthere.php and supply your post code. Other countries - have a look for your country's equivalent web site.
[SATTYPE]
1=5000
2=Mendip
[DVB]
0=6
1=778200,8,|C59 Mux 1
2=746200,8,|C55 Mux 2
3=802200,8,|C62 Mux A
4=826200,8,|C65 Mux B
5=754200,8,|C56 Mux C
6=842000,8,|C67 Mux D
I'm in the same area so I'll give it a try, thanks.
