I have a problem with switching to dvb-s2 Tranpoder(Timeout 10~20 sec)
Alex Sandik
I'm using the latest driver for my TeVii S460 DVB-S2 card with 4-in-1 multiswitch
DVB-S ->DVB-S or DVB-S2 ->DVB-S Tranpoder switching all normal <1 sec,
but DVB-S -> DVB-S2 or DVB-S2 ->DVB-S2 Tranpoder switching Timeout 10~20 sec
Edited by Alex Sandik
There are two possible reasons:
1) Some DVB-S2 channel settings like FEC, Modulation, Pilot Symbols are not correct, so the driver spends a lot of time with trying all variations.
2) A DiSEqC timing issue: Your switch is not fully powered up when the driver sends the first DiSEqC command.
Since the DVBViewer Pro channel editor does not allow to edit Modulation and Pilot Symbols, you will have to use TransEdit (see members area) to check and update your transponder lists. Unfortunately the current TransEdit version 3.3.2 is not able to detect TeVii devices automatically (will be fixed soon), so you will have to apply a work-around (see here). Additionally you will find DiSEqC related hints for speeding channel switching up in this thread.
The board helped channels were switched rapidly:
TransEdit.ini shows that the device should have been detected as TeVii by TransEdit 3.3, but the Vendor.1 entry in the [Hardware] section is still set to 0 (must be 15).
I change то 15, channels were switched rapidly.
Thanks a lot.
It should be ok with TransEdit 3.3.3 (uploaded yesterday) after performing Settings -> Hardware -> Detect Devices. Is it? If not, please attach your TransEdit.ini.
Ок Thanks.
I will write a response when going home at night
TransEdit 3.3.3 Autodetect tevii s460 work right.
