ter9999 Posted May 7, 2009 Posted May 7, 2009 Could anyone please confirm whether KNC1 DVB-S2 card can support C-band reception in DVBViewer Pro? I asked the KNC1 support for C-band reception, they said the card can support. But I used DVBViewer Pro 4.0/4.1 to test that the C-band transponder signals can't be locked using this card together with a 4-in-1 multiswitch (I setted correctly in the Diseqc menus). I have another Twinhan AD-SP400 DVB-S2 card connected that can work with C-band and the same 4-in-1 multiswitch very well. So MAYBE DVBViewer don't support this card C-band? It's strange because the Ku-band reception is good in DVBViewer. Thanks! Quote
Griga Posted May 7, 2009 Posted May 7, 2009 So MAYBE DVBViewer don't support this card C-band? The handling is the same for all cards. In contrast to DiSEqC, which is device dependent, all drivers get the same frequency and LOF data via the BDA interface. Quote
