CAID Selection
Hi All,
I try to use my regular subscription to the italian provider SKY.
The encription uses two caids 919 and 93b. I have a card NDS3 so 93b, but it is not possible to select the right caid that it is always 919. And it does not work.
Can someone clarify it to me?
Thanks
Bye
Frodo B
That is not the problem of the DVBViewer. The CAM should selects the right one when the smart card is inside.
